You might also be able to bore and sleeve it to fit 96mm TD42 pistons...... TD42 piston kit comes with sleeves.
since we were talking about pistons i thought i'd post this pic of piston from working 12ht
I can easily imagine how 2bar might be bit much if pistons are even near that condition (which they usually are around 500 000kms)![]()
Blis, do you know of a Mercedes piston that could be used in a 12HT - I doubt there is enough metal in an OM617 piston to machine in a swirl area...
just wondering if there are Izusu engines that share much of the jap tech .. those piston can be sourced from Izusu .. ?
actually I'm using an Izusuu cluthc and know there are many other thinks that can be the same ..
I believe steel reinforced top ring lands are called "alfin". No idea whether that's a trade-name/brand or the generic description.
A bit of a hijack here. Tapage, can you give me ALL details on your Isuzu clutch... pm if you don't want to show them here..
x2 I'm interested as well
