what exactly does porting the box do, and what would you recommend someone runs to the sub if they run a ported version of your box. i still kinda want to be able to blast a little bit.
First off where did you get the pic of that hottie standing in front of the fridge!? I want to see the "full size" version!
Secondly, you don't need a ported box to pound. The last 9 or 10 boxes I have built (including the boxes for my 15" home subs) have all been sealed and they absolutely pound. It's a misconception that a ported box "pounds" better. The advantage is that you can get the same volume at much lower power levels because the speaker is easier to move (but also less controlled) which makes it a little "muddier". You also need to increase the internal volume of the box which is not easy if you want to keep it out of the interior compartment of the 80. If you want to have a very good sounding box that hits the low stuff and will wake up the neighbors I can build you one without too much difficulty. But you will have to cover it with your own material since it's not gonna hide behind the factory panel like the one Steve built. But it will "pound" like you want it too. You have to decide what you want, I chose to "pound" myself since it is fun every once in a while.
I think I can even fit a 12" sub in the side of the 80 but IMO it is overkill and a good 10" will hit just as hard but actually sound better doing it.
I imagine it's a competition car?
