Stupid Question - Likely....
Albany, Oregon
My under seat heater does not work and I am guessing it is due to it being all seized up inside. The heat level selection level will not move and the components inside the heater looked oxidized and corroded. I want to remove it and break it down to see if its possible to repair it. So my question is this. The hoses underneath that feed the heater - are they filled with some sort of fluid that circulates from the engine?
In taking them off and capping them, am I going to mess something up?
Is there a DIY video on this some place?
I am becoming more comfortable with stuff as I watch videos and ask questions on here. I have now completed my OME lift. And have a knuckle rebuild kit en route. Trying to save some cash by knocking out some of these non-engine related projects on my own.
yes they are filled with the coolant that goes through the engine. instead of capping them i’d suggest hooking them together to allow the coolant to flow as flows from the engine through the heater core and back to the engine. just take them off the heater core and hook them together temporarily to allow the coolant to keep flowing while you fix your heater
yes they are filled with the coolant that goes through the engine. instead of calling them i’d suggest hooking them together to allow the coolant to flow. as it is it flows from the engine through the heater core and back to the engine. just take them off the heater core and hook them together temporarily to allow the coolant to keep flowing while you fix your heater
Is it under any sort of pressure when the engine is off?
no pressure but it will drain out from gravity. i’ve used a vice grip on the rubber hose to clamp them before taking them off and that minimizes coolant loss until you can connect them
Be VERY careful removing the hoses from the soft, thin, brittle, brass tubes that come down from the floor. VERY easy to twist or kink them. Best to slice the old hose with a fresh single edge razor and peal them off.
I am guessing I can just find a male to male adapter and some hose clamps that will complete the circuit?
If you want to keep the rear heater (when you fix it) just use a U shaped 5/8 hose and some new clamps and cap the Heater core tubes to keep crap out of them.
Not sure if this one is 5/8 but you get the idea
Amazon product ASIN B000C2U8Q2
When I first in bolted the heater I wasn’t aware of the lines. Was confused on how it wouldn’t come up until I looked under and saw the hoses. So I am assuming the connections holding the hoses in place are completely outside the rig since there would be no way to get a wrench under the heater.
So under the rig is where I detach the hoses and insert this pipe to connect the lines? Zip tie her in place and plug the holes in the floorboard some how?
Remove all the worm clamps on both hoses 80 and slice the hose with a razor and peal it off the tubes coming down from the rear heater and also off the two hard lines (71).
Then use something like a U - tube above or loop a piece of heater hose to connect both lines 71 together, bypassing the rear heater.
Remove and repair or replace the rear heater as necessary. There are only 2 or 3 bolts holing to the floor. Remove those and pull up (after removing the pass seat)
You can also delete the rear heater (there are threads on that) if you don't need it.
This. It is as simple/straightforward as @Spike Strip is making it out to be.👍🎯👍
If the heater is done for do I loop 72 and 64 together in the engine bay to delete it completely. I found one thread on the delete and it was way confusing and didn’t use the diagram you just sent. Looks straight forward based on this graphic.
No, there's better way to delete the rear heater and there's a very good thread on it. Search sucks, you'll have to dig a bit. But easiest would be to just do that bypass of the rear heater with a U-tube, but not the cleanest way.
I deleted mine using the hose in this thread:
Roger that. Thanks for all the help
When you get into it, if you have questions, post up a new thread and people will walk you through it, if you get stuck. In South American markets Toyota offered the 60 without a rear heater, and that's all we're copying, is that So Am set up. I'll post a diagram tomorrow or so. It's a really easy switch with the hose in the above linked thread
If you want to delete the rear heater, this post has another take on it.
Yes, if the engine is hot!
No, if the engine is cool.
Do this after the truck has been sitting for several hours. If the big hose to the radiator is squishy, the pressure should be low.
Last question on this one, what did you all use to plug the hole in the floorboard after the heater delete?
Metal Duct Tape, but Imma cheap bastid.
There are proper chassis plugs someone showed in one of the threads
