- Joined
- Sep 26, 2003
- Threads
- 117
- Messages
- 11,199
- Location
- Lancaster, Ohio, USA
- Website
- www.tlcperformance.com
A cleaner solution is a generic molded 90* 5/8 heater hose. Available from FLAPS.
Jim... I haven't removed that hose yet but the OD seems like it is much larger than the 5/8 ID hose I bought... Is the OEM hose a lot thicker material than "normal"?A cleaner solution is a generic molded 90* 5/8 heater hose. Available from FLAPS.
Well, I ordered one of these 1/2" NPT SS barbs to see how it works. Could be BSPT, but I held the Union pictured above next to a known 1/2" NPT and it looked identical, but we'll see -- As for the hose, I'll prolly just use straight hose if I can't find a comparable molded for the NLA OE hose.
Can’t wait to hear how this works. I’m interested in deleting the rear heater, and don’t want to put a plug in a pipe that I could just replace with a new pipe and no need for a plug. Need to do a minor cooling system refresh. Who even uses the rear heater? If I delete it, I don’t want to throw away the parts. I’ve saved enough old stuff I’ll never use lol.
All front heater hoses, including hose from vertical barb, over VC to front heater valve, are 5/8" (16mm) ID.Jim... I haven't removed that hose yet but the OD seems like it is much larger than the 5/8 ID hose I bought... Is the OEM hose a lot thicker material than "normal"?
Agreed. Try adding into the dimension being a female. Ha!nothing is worse than showing up at a napa or other parts place and saying you are looking for a hose with a bend and diameter of such... they say "what's the year and make". I find very little parts guys can work with me to find solutions that are not per original configurations.
