mypancreasbroke
Last weekend I started replacing my suspension bushings. Bought a press, Wit's End bushings kit, the whole 9 yards. I've searched through the forums, and haven't found a solution, and just spent the last 2hrs trying to beat the cold steel hell out of the bolt I can't get in.
Upper control arm, rear axle, passenger side. I can't get the bolt to go through the last housing on the axle. Ive tried lifting the body/frame as high as it will go, jacking each side of the axle as much as it will go, lowering the axle as much as it will go, every combination in between, and the damn bolt just wont go through. The springs on the axle side of the housing make getting the bolt out a real b. But Ive tried bolting the axle end first, then bolting the frame end, and same thing. I can get the bolt through the housing, bushing, and other side of the housing on one end. Then the bolt through the housing and bushing on the other end, but it doesnt line up enough to go through the last side of the housing.
Any other tricks out there? Both housings look to be straight, and not bent, same with the control arm. But maybe something has warped slightly? Bout to get out of town, and between storms right now... and wanna finish this dadgum job today. Thanks!
