bloc
What kind of pitman arm puller? I use the following on upper ball joints and it works great. If torque is getting very high, hammer on the end of the driver bolt and the shock while under tension will get a LOT of stuck stuff loose.Thought replacing the replacing the upper ball joint boots on my 2000 Land Cruiser would go smoothly. Driver's side came apart with one blow of the dead hammer. Passenger side, however, won't budge. Hit with hammer several times and no joy. Put a pitman arm puller on but because of the way the arms are configured, the puller can't sit on there straight so pulling at an angle doesn't work. Looking for ideas. Will try heat tomorrow.
Amazon product ASIN B0002KO0PO
That said, I see you aren’t working on a 200 so I’m not sure what I use will fit on yours.
