hi everyone, since I bought my truck in 2019 I have always noticed the same problem, despite the various interventions and the engine refurbishment it has not been solved, it is not an impeding problem in daily use, but it is enough bothersome. I changed all the pipes, the pump diaphragm, the filter, I cleaned the tank, I never cleaned the injectors but I don't think they are the ones. The problem is, when you go up mountains, so in 2x4w the truck really loses a lot of power. Maybe you start the climb on the road and you're around 60-70kmh and as soon as you take the slope it dies, at the most you go to 30-40 pulling the 3rd gear full throttle... even on the road it's a bit dull... more ' of 90 kmh does not make them. The engine has been redone, I have no leaks, the exhaust has no holes (at least it doesn't seem to have any)... in every season and at every temperature, the diesel comes back in less than 8 hours of downtime. for example... I get dressed.. I go downstairs.. I go to start the car, insert the key and turn around.. the scooter makes many revolutions before starting the car (the glow plugs are new) and then it starts. .. in winter everything is amplified, first you give it a few laps, then you remove the key and give it back and the truck could even shut down before leaving regularly! I've already installed a non-return pre-filter, but nothing changes. Any advice? I thank you in advance, I don't know what to do anymore honestly!
