If left exposed to the atmosphere, fuel in California goes bad in less than 30 days. The only way to prevent this is to not allow air to contact the fuel. The little jets and orfices in the carburetor allows air to contact the fuel.
Hi, After just cleaning out the carb in my chain saw, water blaster, tiller...... How do you properly put up gas tools when they won't be used for awhile...
The plastic CARB/EPA cerified fuel storage cans everybody loves so much is actually a different polymer. The polymer prevents permeation of air through the plastic.
I already run the gas out of the carb if there is a shut off.
This is a good practice but the fuel in the tank has more than likely gone bad. When you start the unit up, you are sucking in the old fuel into the carburetor.
Most of my gas tanks are metal so I don't wont them to rust.
Chemicals in the fuel will eat the galvanization off the inside of the metal fuel storage cans as well as fuel tanks on the engines. Ethonal is one if the chemicals. If you removed any gray paste off of the inlet screen in the carburetors you just rebuilt, that is actually the galvanization from the inside of the metal fuel container.
All the carb bowls had crud and rust in them. do to the eth. .
Ethonal is corrosive, which makes it an excellent cleaning agent. It will clean the crud from the tanks and lines of the filling station, your fuel storage can, your fuel tank, your fuel lines and it may eat the fuel filter. All which end up in your carburetor as "Crud".
Metal containers allow condensation, just like a cold beverage. The Ethonal captures the water. When the ethonal is totally saturated, you will see the water droplets in the bottom of the tank.
The rules used years ago no longer seem to work which said just leave gas in the tank and run the carb Dry.
The problem with most people, even years ago, is that they never read "between the lines" the directions on products such as Sta-Bil and other fuel stabilizers. The fuel stabilizer does nothing to preserve the octane of the fuel, it only helps prevent "Varnish". In years past, it stated "Add X # of squirts and run the machine until the exhaust odor changed. Before you start the unit, drain the fuel and add fresh fuel". Most people add the few squirts and run the unit and shut it off. When they go to start it next spring, they fire it up and try to run the old low octane fuel.
The rules used years ago no longer seem to work which said just leave gas in the tank and run the carb Dry. Tired of ruined metal gas tanks. Thanks, Mike
Prepackaged fuel such as SEF, Tru Fuel, 50:1, STIHL MotoMix are pure fuel with no additives. The STIHL Motomix adds a layer of Nitrogen to the can after it is filled. It creates a barrier to prevent air from contaminating the fuel. After you open it and use some and put the cap back on, it still has a 2 year shelf life.
At my place, I use fresh 91 octane fuel from the pump and run my equipment. Towards the end of the season for that peice of equipment, I make sure that the last tank of fuel I use is STIHL Motomix. The 50:1 fuel/oil ration leaves a nice oil film on everything and the pure fuel aspect prevents varnish build up. Next time I go and use it, I add fresh fuel it starts right up.
Sorry for the long answer but you had a lot of questions.
Regards,
Dan
