hello all,
I'm fairly new here (though have been lurking for a while) and I have a issue with newly replaced brakes. I have been searching for the last couple of hours on this forum, but have not been able to find an answer or any suggestions as to what it might be.
I have an 1986 FJ60 which is in a pretty standard condition. It has been extremely poorly maintained and is in need of a complete off-frame rebuilt/restoration, at this point I just need to keep it rolling as I need it for work and hopefully in the spring I will get time to start a re-built.
One of the very bad things on this vehicle was the brakes. So I just replaced rear drums, brake shoes, front rotors, calipers and brake pads all which were worn way beyond acceptable. The issue I'm finding now is that the front brakes loosen up to slow after releasing the brake pedal, resulting in rotors that run way to warm. At times it takes as much as a full minute or even longer before the brake pads reduce their pressure on the rotor. Calipers and brake pistons are all new as well as the rotors and the pads. DS and PS seem to have both the same problem, making me think that it is higher up in the system.
Where do I start troubleshooting? The rear brakes are functioning normal and are not running warm.
Thanks in advance.
PS forgive me if this has already been dealt with somewhere else on the forum, in that case, can someone please get me a link to that specific threat?
Thanks in advance.
