I am going to get some high grade SS metric bolts for the cat. I have hardware store SS bolts now with no problems.'
Is there any problem with using SS bolts on exhaust?
As the SS doesn't rust, will the SS nut work its way loose over time?
Does the heat have any affect on the SS?
Other than sticker shcck, is there any reason I can't use SS bolts on the rest of the 80?
I have found several body bolts that are well rusted.
Is there any place I wouldn't want SS bolts?
As for motor and drivetrain, when I need to replace bolts, do I need to get the bolt from Toyota or can I just get a grade 5 or harder bolt? If I replace a bolt that is a grade 5 with a harder bolt, could there be any reason not to use the harder bolt?
