I’ve had a lot of experience with stainless fasteners in the marine industry. There are a couple things to keep in mind. First don’t run them in/out with an impact gun, the threads will gall and the bolt will seize, try to only use hand tools, secondly if you can get it they make anti-seize for stainless fasteners, this helps prevent the galling and keeps them from corroding and seizing to the nut or threads. Also, if the road crews use any salt or deicer on the roads in winter it will cause corrosion between the fasteners, it doesn’t matter if your 3000 miles from the ocean, the chemical reaction is the same. Personally I avoid stainless fasteners unless it is absolutely necessary, like under water, it’s generally more expensive and when it does seize up it is much harder to remove, they tend to snap off.
Just my two cents.
