I've been enjoying going through my newly acquired Hundy to get to know her better. New tires, New Windshield, fresh oil, tranny, t-case, front and rear diffs. But, I had an airbag light on so couldn't get it inspected. Had a local garage read the code for me which was B1153 Seat Position Sensor fault. The mechanic thought it was probably an occupancy sensor and said it would be $150 to diagnose and then $$ for a new sensor or sensors. So, I turned to Mud and found a thread in which another member had the same problem on his '04 and discovered it was a broken wire to the connector. Turned out mine was the same. Put together a little DIY for those of you that encounter this same problem.
Parts you'll need:
1. Connector Housing 90980-12195 $4.68
2. Repair Terminal 82998-12720 $13.41 (you'll need 2)
Here's the broken wire:
Here's the terminal repair kit and new connector housing:
1. Remove white end cover from the connector housing, slide in the two new terminals, and reinsert white cover:
Now you're ready to install in the LC.
1. Remove 4 seat mounting bolts (14mm) on driver's side (no sensor on passenger's side).
2. Disconnect negative battery lead.
3. Flip seat up to get access to the seat position sensor.
4. Splice in new connector to existing wires (Blue wire on left, Red wire on right)
5. I chose to solder mine and use heat shrink wrap to keep a factory appearance.
6. Lil electrical tape and a couple of wire tires so no loose wires moving around and voila, you're in business!
7. Reconnect battery, reinstall seat, and fire her up. No airbag light!
Total cost $28 with shipping! Hope this helps someone down the road.
Parts you'll need:
