Squeaky suspension
NE FL
Noticed a squeak/creak in my driver side rear when going over bumps. Replaced my springs w 865s about 6 mos ago. Could this be likely shocks or springs? Anything else I should check?
I have a similar squeak on my drivers side rear. I haven't head time to deal with it other than a search of Mud. My searches point to a loose nut on the top shock mount. It is a 22mm nut and you need to pull the spare to access.
What's the fix in the swaybar? New bushings?
I have this as well. anyone figure it out?
Make sure your springs are seated in the lower mounts correctly. They can only rest in one particular orientation and if they're not then that could be your cause.
My squeak was from the control arm bushings. Sprayed lithium grease on them and let it work in. All the squeaking stopped. Probably time for new arms or bushings.
Yeah I'm getting this to going over speed humps etc ,but once car warmed up goes away.Very hard to find.
