'97 LX450
I'm chasing a very infrequent no start situation and have tried numerous mentions here to fix. No start meaning single click heard when turning key (all lights/radio/air as expected) but no crank.
It comes and goes at the most inopportune times- but moreso a) when it's super hot outside b) after I've been driving aggressively c) when I need to be somewhere.
I'm not sure how to chase this one down.
What I have seen is that during these times, the volt on my ultraguage show a drop to 11~ which I'm sure is causing the issue. In the good starts, battery is in great charge and readings hold mid 13s at idle. When the no start occurs, I cannot jump off the car- which is more frustrating- my noco jump box is rated to kick over cement trucks (I've proved that!), but is unsuccessful at connecting properly during the no start period. So I'm assuming it's that weird ignition needs to detect a certain amount of voltage to activate the starter issue- but how is this still a thing after all the replacements.
I typically let the rig rest 30-45+ mins and retry and all is well (volts show perfect on UG and truck acts like nothing happened)- as you could guess, 30+ mins stranded in the NC heat or late for an appt makes wife angry!
So I want to focus more on the ignition to starter connections- is this where that voltage must have a certain reading to activate the starter? I'm wiring diagram dumb, and need Fischer Price level discussions...lol.
- toyota/ reman 80 amp alternator
- battery in good holding charge
- no cable corrosion- battery/starter/alt
- new ignition switch
- new denso starter
- fusible links are in great shape
