I recently bought a new speedometer gear, 6x18, I installed the new one and jumped for joy when the speedometer cam back to life
(this was Monday) At the end of Tuesday the speedometer didn't work anymore, got home and pulled out the speedo gear, it was a little messed up, I regreased it and took out the o-ring that was making it a bit tight, it was making a lot of friction. It worked for a good while but after ten minutes it just didn't work anymore, could it be that the speedo gear is messed up enough or should I check out the transfer case gear.
For more information I used white lithium grease for the speedometer gear and the speedometer cable is turning by the power of a drill. Nothing is frozen. It is just the speedometer gear.
(this was Monday) At the end of Tuesday the speedometer didn't work anymore, got home and pulled out the speedo gear, it was a little messed up, I regreased it and took out the o-ring that was making it a bit tight, it was making a lot of friction. It worked for a good while but after ten minutes it just didn't work anymore, could it be that the speedo gear is messed up enough or should I check out the transfer case gear. For more information I used white lithium grease for the speedometer gear and the speedometer cable is turning by the power of a drill. Nothing is frozen. It is just the speedometer gear.
