speedo woes
i broke 2 speedo cables in 1 week, up at the speedo housing. Has anyone taken out the speedo and cleaned it up inside, so there is less resistance?
thanks
Jan
IIRC, there is a c-clip that holds it all together at one end, remove that and the inards slide out so you can re-grease.
sounds good, thanks.
I found the answer by searching-apparently the speedo itslef can be cleaned with electrical parts cleaner and brake cleaner.
Jan
sl33py said:
what did you search for to find that? sounds like a good idea!
I searched for 'speedo cable' and a lot of threads came up, some useful.
j
