speedo calibration correction for 2006 Landcruiser?
I see the calibration corrector from superlift for up to 2004 Landcruisers, but I don't see a speedo calibration corrector for a 2006 model.
Anyone?
Go with a scan gauge. You can easily calibrate the speedo given the adjustments in the system. I also use mine to monitor the accurate MPG (given tire correction), and AT temp.
Plus, nothing beats having an OBDII scanner at your fingertips all the time for any pesky codes that may pop up
DJWUZJ is spot on with the SG. It will correct the speed, however it will not correct the Land Cruiser's tach/speedo/shift points. Slee sells a speedo correction tool which intercepts the signal by the transfer case and adjusts the shift points, and speedo/tach appropriately. The Mark's 4WD adapter says it's for 80 Series LC's only, I know a few that run them in the 100's with no issues. It's on my list of things to do...just not high up right now.
Mark's 4WD Adapter:
http://www.sleeoffroad.com/products/products_speedo.htm
DJWUZJ is spot on with the SG. It will correct the speed, however it will not correct the Land Cruiser's tach/speedo/shift points. Slee sells a speedo correction tool which intercepts the signal by the transfer case and adjusts the shift points, and speedo/tach appropriately. The Mark's 4WD adapter says it's for 80 Series LC's only, I know a few that run them in the 100's with no issues. It's on my list of things to do...just not high up right now. Mark's 4WD Adapter: http://www.sleeoffroad.com/products/products_speedo.htm
I want that real bad... My speedo being off freaks me out sometimes...
