Speedi sleeve semi floating rear axle shaft - which dimension has the oil seal surface ?
Opotiki,Bay of Plenty New Zealand
Hi wordlwide team,
A friend of mine has a leaking fj45 semi floating rear axle - he knows that the oil seal running face is not great. I'm planning to repair that face with a speedi sleeve.
I have done that before on other applications - but all my trucks had and have FF axles so nothing to measure here...
Has anybody of you the required dia. for the sleeve at hand ? I believe that the oil seals are the same for 40 55 and 60's so the dia. should be the same as the 60 one.
Like this I could get the sleeve before removing the shaft.
