special oil pans?
I have a 1984 FJ60 with a GM 350 small block and an auto 700 R4 tranny. They are hooked up to the original transfer case and the oil pan for the tranny is kinda smushed from the CV joint being so close to the pan. I was wondering if anyone knew of a special oil pan that would fit nicely and wouldnt have to be crunched. Thanks
you already have the special oil pan...........is it leaking......??? if not leave it alone untill you adress the drive-shaft problem.........
