Spec & good source for Anderson connectors?
Metro NY
Looking for flush/panel mount (and matching "on wire") connectors in sizes for smaller (up to 30a for ARB fridge etc) and larger (up to 150a for charge wires to a remote battery) and largest (300-400a for full output to winch, jump start etc).
These will all be in pairs (+/-).
I'm not familiar with names/numbers of the styles/models of connectors... if anyone can point me at the right parts, or a place where I can figure it out myself.
Is there a mud-approved source for these?
Thanks,
mark
If I could add that on the above Powerwerx website there is a very good crimper tool that does a great job on the under 45 amp crimps ( 45, 30, 15). You could get the multi use crimping tool that does a bunch of other crimps too (MC4, coaxial, 50 and 75 amp PP's and the standard blade connectors).
Powerwerx is a great source. With the smaller power poles, the ratcheting crimper is basically mandatory. I find the pre-fused housings are easier to use and automatically make you preserve the standard polarity convention. The 15/30/45 flavor of the small power poles is super useful.
Regarding the larger SB series power poles, SB50, SB175, SB350 which is a tougher monolithic housing and highly recommended. The numbers don't mean what you think though, For instance the SB175 has a "hot plugging" rating of 175 amps, but it's continuous duty rating is 280 amps. They originally developed them for forklifts where I guess "hot plugging" is a thing.
Warn sells Anderson SB175s as their winch disconnect and I use the same. You don't need the SB350s but you can use if you want but they are big and hard to plug and unplug. Also check that there is a terminal for the size wire you want to use.
If you really want to geek out, the SB housing colors actually matter. Yellow is the specified 12 volt connector. I use blue which normally is 48 volt but I got a whole bag of them surplus for about $4. In fact, if you just need 2 for a winch disconnect, I'll send them to you.
Anderson Powerpole - Wikipedia
It also helps to have a couple of common color bare housings to assure you'll always be compatible with your with others who might not use the same color you do. Carry a red and a yellow then you can use whatever you like. This came up last year when a friend had his portable welder set up with powerpoles and we had to swap around connectors in real time to use my jumper cables to power 1 side of the welder.
^ great idea carrying a couple different colors in the parts/tool bag!
And it's worth mentioning that the colors will not cross connect. They are keyed and each color is different. So red only connects to red, blue to blue etc. I think one of them (?possibly black) is universal and can be connected to any color.
edit: I looked it up and Black is "keyless" so you could just toss in as a universal spare.
AFAIK there isn't a universal/master color in the Powerpole system. Black and gray are the only two different "colors" that are cross compatible. I have a few black SB50s and they will not connect to my red SB50s.
Regarding color of the SB series, note that there are Chinese knockoffs of Anderson housings floating around and the color/keying of the knockoffs doesn't match the color/keying of the real Anderson connectors. This can really make things confusing, so best to stick with the real thing.
