Spare Wheel/Tire Orientation
Mount Airy, MD
Here's another thread for the 80 guys and girls to chuckle over.
I just had all five OEM 18" alloys refinished [powder coated] and new 275/70-18 BFG AT KO's mounted up. I am on the fence about which way to orientate the spare which will be rotated in every 5,000 miles. When I removed the spare to have it refinished, it was face [outside] down. There was dirt and even water trapped behind the spokes. The Owner's Manual states that the spare should be orientated face [outside] up. This would be my preferred orientation—the refinished surface of the wheel in the spare location would be less likely to be scratched from debris either on or off road, and dirt and water would not be trapped behind the spokes. The problem is that the spare is pressed against two bars, one near the axle and another near the trailer hitch. Though these help prevent the spare from moving [significantly], looking at the Bridgestone Dueler that had been sitting under the truck for at least the last 18 months, there are two abrasions on the tire where it was pressed against these bars.
For the foreseeable future, this 100's main duty is hauling kids to practice and driving up an down the East coast to Ironman triathlons. Any suggestions about what to put around the bars and/or between the bars and spare to prevent these abrasions? My first idea was two short lengths of black rubber hose, or a bicycle tube.
As always, your experience and advice is appreciated.
That rubbing on the tire was most likely the result of the spare being mounted the wrong way, thus allowing far more play over bumps, etc. then intended. Think about at least 10"of that spare cable being extended vs. approximately 2" if mounted the other way. If you place the spare w/ the face of the wheel up, the cable is barely extended and will allow you to get a very tight fit against the stoppers.
I just pulled my OG spare down to replace it w/ a 285/75/16 and there was nare a mark on the tire which shows an '01 manufacture date. I think the key is proper mounting of that spare.
mine had this so I'm sure everyone's does...
the hanger off the cable that you put thru the hub hole has a little finger that points up, make sure that is in a lug hole. Otherwise the tire will be wobbly and not fit in there quite right.
Does that make sense?
Hmm, I had mine down yesterday and didn't notice a little finger. Might have to spin it down again to see if it is there.
I was very tempted to do the spare tire mod while I had it down but I didn't have enough time to get it done...will save it for another day.
https://forum.ih8mud.com/100-series-cruisers/76405-spare-tire-modifications.html
I've always wondered about that... mine is face down as well. I'm going to flip mine around so that the cable is "shorter" as mentioned.
Regarding the cable that holds the spare up... I vaguely recall hearing something about an updated version. something about the update having a chain vs cable?
It's been awhile since I had a spare down there but I suspect when the wheel is face up (as it should be) and cable is overcranked, you'll get marks on the rim face. Maybe you should've gotten the 285 width.
I once mentioned the updated chain vs cable but I think it only applied to Non-US 100's.
I had my spare mounted underneath, I can down hard on a rock ledge and the spare tire was underneath. It bent the cross member and the lifting mechanism broke.
Spare tire was fine, the rim was scraped up and the tire was a little scuffed up.
.. Any suggestions about what to put around the bars and/or between the bars and spare to prevent these abrasions? My first idea was two short lengths of black rubber hose, or a bicycle tube. As always, your experience and advice is appreciated.
How about a spare tire cover? Amazon.com: Bully CM-02 Large Universal Spare Tire Cover: Automotive: Reviews, Prices & more@@AMEPARAM@@http://ecx.images-amazon.com/images/I/41eqnnafJqL.@@AMEPARAM@@41eqnnafJqL
Just rip a hole in the middle with a utility knife to poke the carrier through and voila.. would be a little cumbersome to remove but it's only twice a year, right? :meh:
