What are you going to do when the N74XXL's come out?![]()
They won't work with 35's and a Slee Bumper. Any more travel and the bumper will stop the tire cold. Thought you had me, huh?
Nope. To add in a brake line means add in a new piece...need to bleed...possible leaks...better to not touch stuff unless it is needed which it is not. Clear enough or still circles?
Well, IMO, it really is no big deal to bend hard lines (though usually they don't leave them out in the open like that). And it is also no big deal to swap a brake line and bleed the brakes. My point was the brake line needs to be addressed, that's all.
In your own words, yours is a mod as well....the relocated stock lines provide enough length for even this travel. No danger here. So the mod is gospel...
Yours has been 'touched' as well....better to not touch stuff unless it is needed which it is not. Clear enough or still circles?
if you're extending/replacing the lines on all the wheels too with steel braided, you should consider that five steel lines might make more pressure or otherwise stress the last rubber line beyond its design parameters... i had lines made for both rr axle lines, works beautifully![]()
