I put this stuff in my 60 Soffseal Sound Deadeners INSUL1
I chose this as I also did the same stuff when I redid my Chevelle It was inexpensive and I wanted something that would deaden the noise and heat well.
With dual 3" exhaust tucked up tight and long tub headers my Chevelle never got warm enough inside or on the floor for me to worry. It cut the noise (as much as you can expect from something like that) and worked real well.
When I did the carpet on my 60 I used this though out. Due to it being fabric I did make sure my floor was clean and sealed (also pained the whole floor with POR 15 first after the rust repair.
2 packs cover the whole floor with ease.
While I am still rebuilding my 60, I have zero doubts this will work fine. For the areas where I wanted it to stick (around curves etc.) I used a little spray on glue so I could pull it up if ever needed.
