EDIT: The part number is 32943-60121. Leaving the below in case anyone has the same problem I did and runs into this post via search.
Recently ended a trip short as one of my transmission oil cooler hoses got a nice cut through it, sending ATF everywhere while I tried to get over to the shoulder of the freeway. I'd like to replace this hose and find out if I got over quick enough to avoid damaging anything but the hose itself.
Tried to replace with 3/8" ID from the local parts store but (with entirely too much effort) had no luck getting it over the barb in picture #1. Having pneumonia at the moment certainly doesn't help my desire to fight with this, and after trying various lubricants to assist me I'd rather just get the proper 10mm hose and be done with it.
The hose in picture #3 is what I'm replacing, though it was originally protected by a larger hose around it (which was removed for use on my failed replacement).
tl;dr: I need to order a replacement for this hose - please help me identify it in a manner which will let me do so?
#1: The old hose, prior to removal, at the end which is giving me a very bad day (and at which the cut was found)
#2: The other barb the hose (now removed) should go over - this is located under the battery box, and is a short metal tube that goes through to the front before transitioning to another rubber hose going to the transmission cooler; this goes to the lower side of the transmission cooler.
#3: The hose itself, sans the original protective wrapping which was over it. As pictured, left end goes to barb in #1, right end goes to barb in #2.
Thanks!
Thanks!
