- Location
- United States
SOLD
$25,000 OBO
$22,500 OBO—EDIT: See last few posts below. Willing to deal for quick sale. More pics and info added at end.
Purchased January 2016 from dealer in OKC w/ ~111k miles. 1 previous owner, listed as corporate vehicle on the clean Carfax report. Regular, routine maintenance (I have records from dealership ). Current odometer ~149,400
VIN: JTEHT05J232047871
Post purchase (March/April 2016) inspection and baseline done by Slee Offroad including:
-Front wheel bearing service
-Fuel filter
-Spark plugs
-Timing belt, front crank seal, idler bearing, serpentine belt
-Water pump
-Drain and fill diff, transfer case, engine oil
-Lube drivelines
-Transmission fluid drain and fill
-Brake fluid replaced, bleed system
-Air filter
-Grease driveshafts
-Drain and fill radiator, clean and fill reservoir
-Heater Ts
-Harrop E-Locker front and rear install with OEM switch
Mods:
-Cooper Discoverer AT/3 275/70R18 and matching spare w/ 30k+ miles on them
-Ironman Foam Cell Pro lift
-Nitro UCAs
-Diff drop
-Airlift 1000 rear suspension air bags
-Exhaust resonator delete
-Dissent aluminum front bumper
-Dissent rear steel bumper (OEM crossmember cut) w/ single spare tire swing out
-Trail tailor sliders
-Trail tailor creeper skid
-Gamiviti Expo+ roof rack with front light bar and rear lights (not wired)
-WagonGear tailgate lid
-Depo headlights
-Slee Group 31 battery tray w/ X2power AGM battery, mil spec battery terminals
-Slee stainless brake lines (rear installed, front supplied at purchase)
-ARB low profile drawer with fridge slide (passenger side, easily removable)
-Wits' End fire extinguisher mount (driver side)
-PFRAN interior LEDs
-YotaMD titanium key fob
-Weathertech floor guards front and middle row
-Switched auxiliary rear Powerwerx panel with USBs, mini Andersen connectors, cigarette adapter plug and/or voltmeter
-Bedliner'ed rear cargo floor 3/4" baltic birch wood base (allows use of 3rd row seat(s) with quick install/removal of drawer)
Recent (May 2019) upkeep/maintenance performed by 2001LC (100 series expert here on Mud):
-Exterior wash, clay bar and wax
-Interior clean/detail including leather clean/condition and carpet clean
-OEM idler pulley
-Tensioner bearing
-Differential drain/fill
-Power steering flush
-Re-torque spark plugs, head cover
-MAF clean
-Replace cracked air box vacuum line, PVC hoses, idle up control vacuum line
-Air filter
-Rear stainless steel brake lines install
-Brake fluid flush/bleed
Known issues (see pictures where applicable):
-Rear window hatch rust--rust free replacement hatch from pre-'03 included in sale
-Wheel arch rust
-Front passenger seat leather (tough/firm)--all other leather in good condition, no tears
-Keyless entry not working due to me haphazardly removing a bunch of PO wiring and getting overzealous (still have the needed electronics for it, just needs to be reinstalled)
-Replaced 2nd row overhead DVD player with OEM dome light but need to fab a little cover over the cutout in the headliner
-Although it's good enough for me, sound system could use a once over (PO wired aftermarket subwoofer which I deleted; ?new speakers, sub +/- amp), including recovering speaker grills
-Handful of cosmetic restoration items (grill chrome, console shifter bezel, plastic seatbelt hooks/stays, broken cupholder, etc.)
-Laundry list of upcoming recommended service per 2001LC:
Coolant flush, thermostat w/ o-ring, wheel bearing, axle bearing/bushing service, transfer case flush, lower ball joint, coil boot/seal kit
-Fuel filter
-Spark plugs
-Water pump
-Lube drivelines
-Air filter
-Grease driveshafts
-Heater Ts
Mods:
-Nitro UCAs
-Diff drop
-Depo headlights
-OEM idler pulley
-Tensioner bearing
-MAF clean
-Air filter
-Wheel arch rust
