- Thread starter
- #41
My logic was in my 24 volt truck (with 2 x 105 amp-hr. marine batteries) -- the solar panels eliminate the need for a heavy 55 lb. 3rd 12 volt RV battery, because the starting batteries are fully charged each day (starting when the sun comes up) and with the capacity to operate the fridge, even when the truck sits for extended periods. That saves me weight, space and 3rd battery replacement costs down the line.
Also I have a Morningstar Sunsaver (US made) MPPT (maximum power point tracking) charge controller which is different from PWM (pulse width modulation) controller, which is the standard technology.
A MPPT controller adjusts voltage to ensure maximum power extraction from the solar panels as the voltage fluctuates through the day. A PWM controller can only use the panel voltage when it’s within the battery voltage range – I think up to 15 volts (30 volts if in series). I have measured my panels (2x 12 v series panels) at over 40 volts during the middle of the day, so that excess voltage is captured, whereas with a PWM charge controller that wouldn't be.
The result is the MPPT controllers give 10 to 30% more power from a given panel over the course of a day, because they account for changes in the panel voltage due to temperature and other factors.
A couple of things to consider before you decide on making an investment.
A 60-80W solar set-up (minus battery) would make a nice Cruiser Days prize.
