As part of my Utah trip preparations I just finished installing two solar panels to power my ARB fridge and keep my batteries fully charged.
The objective was to be able to power the fridge and maintain full battery charge on an indefinite basis -- without running the truck ( avoids smoking up the campsite) or using external power sources generators or shore power).
The third battery is a more popular option, but it still needs to be charged, weighs 55 lbs and takes up space. The dedicated battery option is initially cheaper, but you must factor in battery replacement every 3-4 years. The panels will last 20 years+ and the panel/ controller will have separate resale value..
Set-Up
Fridge - old style ARB fridge on 24 vdc (2.7 amp @ 12 vdc, when operating)
Batteries – two generic (Korean) marine starting batteries (2x105 amp-hrs)
Solar Panels – two 40 watt panes monocrystalline (in series for 24 volt) 24.5" x 21.5" x 1" (mounted across the top within the roof rack)
Charge Controller: Morningstar SunSaver MMPT (12/24 vdc).
Weight: 20 lbs with all hardware (panels are 8.5 lbs each).
More information to come -
Set-Up
and then pack it and stow it securely each time - too busy with other things ..................
