Thats great to know, thanks. Do you have some suggestions then? ...
On a "new" rig with no history, you need to do a full inspection. I start with the rear, pull the drums, check the axle seals and cylinders for leaks, do the adjusters turn, shoes have pad, hardware/springs intact? Repair any issues, put the drums on and adjust correctly.
Jack up the front, check wheel bearing play, should be none. Remove the wheels, any leaks from the calipers, are the pads good, the pins in place, rotors look smooth? Repair any issues.
At the master cylinder, look at where it mounts to the booster, any leakage?
The fluid is hygroscopic, absorbs moisture from the air, it can look good and be bad. It should be changed annually, most don't and is probably the number 1 cause of cylinder failure and gradual brake efficiency loss.
To flush I remove the strainer(s) from the reservoir(s), using a turkey baster or other sucking device, remove the fluid from the reservoir(s), refill with fresh fluid. Go to the first bleeder, open it slightly, place you finger over the opening to work as a one way valve and have your helper gently pump the peddle a dozen or so times until you see fresh fluid. The close the bleeder and bleed normally a couple of times until your sure all air is out. Refill the reservoir and repeat on the other bleeders.
A couple of points about bleeding: It not a race, use normal driving pressure on the peddle, operate it relatively slowly and briefly stop with the peddle fully at the top on each stroke. If the peddle is aggressively slammed the fluid moves at high speed in the lines, causing any air bubbles to be broken up into foam which is much more difficult to remove. Only open the bleeders enough to get a dribble or small arc of fluid and close before the fluid stops flowing. If the bleeder is opened too much and left until flow stops, there is a good chance of sucking air back in, not what you want.
