hey if you here hissing or air leaking you need to see if it happens all the time, when the pedal is depressed or does it do it just as the pedal is depressed (stops when pedal stops moving). a master cylinder can leak internally and cause the problem you are talking about. it will stay full what happens is fluid leaks through the internal seal that is supposed to direct fluid out to separate lines.
