- Joined
- Jul 20, 2004
- Threads
- 274
- Messages
- 23,204
- Location
- Chandler, AZ
- Website
- www.tontorecreationalliance.org
Any tips at getting the drums off when they are stuck? I cant tell if they are stuck on the shoes or on the inside where it touches the hub.
If stuck on the shoes, the drum/axle is hard to turn, shoes dragging on the drum. If the drum is badly warn, there can be a lip on the edge that can catch the shoes. Most times it's debris/rust at the drum to axle mount. I cleanup the exposed part of the axle, then hammer on the drum. Hammering vibration loosens the rust, it can be hit pretty hard, enough to ring the drum, but not dent it. I start with a big punch around the studs, pounding in on it, then hit the outside of the drum, turn the drum a bit, hit, repeat, every couple of inches around the drum. Most times this will loosen them up.
