My friend is currently working on my SOA and he wrote me the following: "was discovered that the driveshaft would turn a small amount. The upper U-joint is in a bind it does turn freely when the axle is sitting even. I can grind on the flange to give the Ujoint clerance this will cause an extreme angle and chances are it could break easly. Another issue is the splines are barely makeing contact. One other idea is to have a custom diveshaft made with a duble carden/ CV joint. so let this rattle around in youre mind and let me know, Jason"
Any ideas? sources? I searched on here for a while and wasn't having any luck. Maybe I was using the wrong key words? Thanks
