Bringing this thread back to life...
I am getting rid of my carb'd chevy engine (its old and needs a rebuild) and putting in a 3FE. I wanted to go back to Toyota drivetrain, and also wanted FI.
I am looking forward to it.
When the time comes, and you could use some help from the North Bay, drop me a line! I can also run pickup for parts at Mudrak's of you need parts moved.
One aspect to this thread that I failed to remain sufficiently level-headed on, and found myself somewhat wrapped up in the gestalt of this topic is: as we've discovered, there is no cost-effective pure-bred Toyota option; however, what of other non-Government Motors parts?
I briefly touched onto Cummins as an option, and I'd like to elaborate on this possible subject. Cummins tickles my fancy in a 40 because:
- An entire parts truck can be sourced for a fair price, and mutually beneficial because parts not used can be resold.
- Availability of replacement parts are ample, and Cummins has a reputation of outstanding customer service
- Very nice power-to-weight-ratio, as we see in 4-cylinder 4BTA's hauling around big delivery vans
- Reliability, shoot their motors are just so simple, and foolproof that, well cared-for, will outlive anything else in our lineup.
- Electrical simplicity, These things have no ECU, or later ones have a simple one. The most sought-after generation is pre-ECU, which further simplifies the swap
- No Carb! C'mon, we all have had problems with even the best-tuned carb. As long as the injection pump's solid, then: no off-camber issues, no sticky accelerator pump, cracked diaphragms, or plugged up EGR ports.
-Off-idle torque. How awesome is an engine that pretty much throttles itself into first, and acts as its own reduction gear?
- No Smog! Just file a change of motive power form with the DMV, get the rig inspected, and you never have to smog again.
- Broad fuel options, Diesel, bio, SVO, WVO, shoot pretty much melted cheese will run one of these things.
- that amazing diesel sound. I'm gonna get up on a soapbox here and say: If you don't like that sound, you clearly smoke crack, and huff paint, while performing autoerotic asphyxiation.
The biggest down-sides seem to be:
- It's still a swap. Swaps will never be cheap, or cost-effective, but if you have no motor to begin with, this is an option that is in cost between a small-block, and something a great deal more expensive.
- Adapters are scarce. I still haven't found a H55 adapter, which would be my transmission of choice. (not a fan of the NV4500.) I would consider the AA Cummins adapter with a Ranger between the H55, but then there would be driveline slop in a SWB 40, but may work in a 45 or 43
I'm considering this as a possible swap when I start my fat 43 project.
Another consideration I'm mulling over is an Isuzu. My neighbor runs an NPR truck for his Modular-home restoration company, and that thing is gutsy! There is a strong aftermarket following for said motor, and the AISIN transmission can be modded to accept an FJ60/62/80 tailhousing and output shaft. A GM Bellhousing adapter can be found, and used to run an NV4500 - or the previously mentioned Ranger/H55F (A combination that may be better off in say an LV, or troopy.)
Beyond that, there's Ferd. I enjoyed Mace's Bob build, and I'll attest to the reliability of a Big-Block Ford V8 with early EFI. Their auto transmissions are kind of a crap-shoot, but a V8 and Borg-Warner 5-speed's an an impressive rig.
GarageRat also mentioned BPO motors. The Oldsmobile 442 was my first love, and it would be neat to run an Olds V8. It's got a higher deck-height than a small-block motor, which means more compression, and rumors abound that BPO workmanship is better than GM corporate hardware. the big catch there is finding an adapter to mate the motor to a bellhousing that can accept a commonly swappable transmission. Parts availability is tricky at times, but there are groups dedicated to keeping the good GM cars alive, I have no doubt there can be pieces sourced. I'm also looking into the possibility of cross-compatible parts. - I'll share my results.
