NLXTACY
Wits' End
Disconnecting the battery cable(s) while a vehicle is running is a common trick to test if your generator/alternator was working properly on older, pre-computer cars/trucks. Now I am NOT NOT NOT recommending anyone do this to their trucks. I only did it because the question came up in one of my product threads but I felt it was good info to share and have it's own thread.
Again, I am doing this so you don't have to nor should you.
This topic seems to come up every once in a while in conversation and I used my past experience to dictate the answer. But I realized I only ASSUMED it for the 80 Series. Well in order to confirm what happens I went ahead and recorded it. This way everyone can see what happens and will then negate the need to do it themselves.
Now, a caveat, I've done a LOT of rewiring on my truck but I am fairly certain that this will net the same affect on even stock trucks.
You can see in the video but basically I needed to know for certain:
• Truck running, what if you disconnect the positive cable?
- what happens on restart?
• Truck running, what if you disconnect the ground cable?
• Truck running, what if you disconnect both the positive and ground?
Care to guess BEFORE you watch the video?
