I have a feeling maybe your hubs are stuck in the locked position which would explain your poorer mileage and if your 4WD is actually working.. In 4WD especially in a 60, it is a clear noticable difference when you are driving it when you are in 4WD. You can check to see if they are sticking, maybe sure its in 2WD and get under your truck and try to turn your front driveshaft. If it spin with your hubs in the open position easily with your hand, then your hubs are working right as they probably are. If it doesn't then they are stuck in the locked position. You can then lock them and spin the driveshaft till the hubs pop in then you should get no movement from the front driveshaft. If it were me, and I used it often, I'd leave them locked all the time except for trips beyond town and when you wanted better mileage... It is pretty easy to rebuild front hubs if it matters. Trent Fab in tahoe could probably do it for you easily. Also lucky Tahoe uses no road salt, that is pretty neat. I LOVE driving cruisers in winter but it is no secret it takes its toll on them... I had an immaculate FJ40 restored by TLC that drove over two winters and rust came in exactly the worse possible spots to borderline need a new tub. Kind of sad unfortunately..
andre
