If you have done the Sniper EFI conversion, what did you do with the display?
I agree. I want to keep it visible rather than leaving it in the glove compartment. I've been toying with placing it where the ash tray is now. Put a plate over the opening and fastening the display to the plate.I put it right next to the gauge cluster on the right. It has helpful data, so I like having it visible.
Thanks for the suggestions!!I used one of the Scosche Magicmounts you can find on amazon.
If you dont like the dual sided tape on that one, Ram makes a magnetic mount that just sticks to the dash with magnets.
Thank you!! I think I now know how to get started. Much appreciated!It's no big deal. Just unplug it from the main sniper body and re-run it how you want. I actually run mine over the brake booster and into the dash with the main harness. My scosche mount is right next to that hole on the right side of the dash, so no holes drilled.
I mounted right of steering column, also mounted a short section of rigid vac hose with dbl stick tape to hold the stylist just to right of it.I agree. I want to keep it visible rather than leaving it in the glove compartment. I've been toying with placing it where the ash tray is now. Put a plate over the opening and fastening the display to the plate.
Sorry, but I have to plead ignorance. The Sniper is pretty much a mystery to me. I did not install it myself. I had my FJ40 at a shop for "restoration". EFI was suggested; I thought it a good idea so I had them convert to the Sniper. I just finished reading what documentation I have on the Sniper - installation and all the various parameters that you can set.. I was hoping to see what "IAC%" meant and where in the menus on the display I might find it, but alas I did not..@Alan Kiecker … if you don’t mind, how is your IAC% setting? I chased that target number for 2 weeks…I’m either at 14 or 0. If I do get 6 or 7..it doesn’t stay long maybe 5-8 seconds then drifts back towards 0
