The Sniper was happy as a clam while the weather was warmer, but it wants to stumble on acceleration with these cooler fall days (30-50* out). It seems like it's some tweaking required in the coolant temp and/or air temp compensation, but it's slow going to tune it as you get one shot a day when it's cold. Past that off-idle accel hiccup, it starts and runs fine.
I'm not losing too much sleep, as it's getting stashed for the winter shortly once the road salt flies, but thought I'd see if any of you in the colder areas have found some tweaks that worked. Letting it warm up until the coolant gets to 125 or so is enough for it to be pretty happy, which doesn't take all that long...but shouldn't need to, either.
Anyone run into that and find any good compensation factors?
