if one is to go to the trouble of having a welder work on the thing, seems like it would be much easier to simply weld a plate on the outside of the frame, and either tap that or have a nut welded on the inside face?
Can you weld? If so, Just weld a bit of steel up there, drill a hole and use a tap to create threads.
If not... hrm... find someone who can?
without the welded nut on the inside the frame isn't thick enough for any threads and if you welded a plate on the outside that was thick enough to receive threads the tow hitch plate would not fit flat.
so you have to reweld the internal nut
actually, that gives me a better idea. enlarging the oem hole with a small holesaw and then welding in a disc the size of the new hole with a nut already welded to it might be the easiest of all.
had the same issue. i got mine from a trailer hitch shop. they do import installs so they have a huge range of metric grade 8 bolts.
