SM 420 rebuild help
Swanzey NH
We are in the middle of a rebuild and have hit a wall.
Mike Smythe's rebuild kit (discontinued) calls for a Toyota
washer #90201-35070. We've called CDan and this is no longer available thru
Toyota.
Does anyone know what this is from, have one or know the dimensions
so we can have one machined up.
We are stuck until we get this thing
Thanks
IIRC-
That is a one-piece Land Cruiser transfer case high and low speed gear thrust washer. Each transfer case requires two. Should not be that difficult to find used.
I can measure one at the shop in the AM and post up dims unless someone else gets them up sooner.
IIRC-
This is correct. If you have a spare transfer case, you have two of these. You can make your own by using a washer of the same ID and thickness. It doesn't have to be hardened like the transfer case washer.
Thanks for the help. I tore apart one of my spare cases tonight and have the washer.
Thanks again!
