- Thread starter
- #21
You say that heat is building up on the clips in the fuse box. Heat is a dead giveaway of high resistance - which you should NOT have at the fuse box. Are the connections tight? Are they corroded? Something is wrong at your fuse connections, if they are getting hot.
Take the fuses out and make sure the contacts are clean. Check the connections on the back side of the fuse box. Make sure the clips are tight against the fuses when the fuses are in.
Yeah, removing the fuse panel and cleaning all the contacts and tightening things up is on the list. I'll be doing that shortly... especially given the issues I'm playing with now. I went for a test drive earlier and this isn't as severe as I had thought.
Oh, and the negative on the ammeter just means you are using more current than your alternator is producing. Does it go away when you come above idle?
Going out to check the various ammeter and voltage readings now... will report back.
