Does this sound correct???
If you're having a shop do it then that sounds right. Two coats of single stage= two times around spraying. Base/Clear means four times around. Two for the color and at least two for the clear. Single stage is just fine on the inside and the shop is in it to make money not waste time. Either way it's going to be slick. I remember seeing a nice product for traction when I put epoxy on my garage floor. It was basically a clear sand that could be sprinkled on with a salt shaker while the paint was still wet as an alternative to the colored chips. Might check with some of the retailers selling floor epoxies if you're interested.
