"for certain parts modular or fuse panels they only register them to work in certain vehicles".
Hey Norm,
It's true that junction boxes can be close to a thousand dollars from the dealer, you can find them online for around $500. The one under the hood is easier to access/replace than the kick panel ones. Here's a thread where someone replaced their #1 junction box, which is under the hood.
This is a vague statement, but one thing they might be trying to say, is that when you install a used ECU, such as from a junkyard, it needs to be reprogrammed to work with a different vehicle. This can be done, but maybe the dealership is refusing to do it, and insisting that you buy a new one. This isn't a technical limitation, sounds like it's their policy.
What symptoms are you seeing that the dealership is diagnosing as a bad junction box? A common issue on these trucks is that a bad windshield seal will cause rain to get in and leak on the junction box, which causes random electrical issues.
That's what happened. Rain leaked in from windshield and got into the fuse box by the driver side door. It caused some weird issues like windows not working, locks not working etc. So they're saying it's corroded and needs to be replaced and the dealership is saying it will cost $2000
If I were you, I would get the cruiser out of the rain, and put a blower in there over night and get the inside as dry as possible. If you don't have a blower, it would probably work to start the truck and run it for a few hours with the heater on MAX, A/C on, vents set to the footwell, and recirculation turned on. This combination of settings will result in the hottest, driest air. Don't leave the car running in a garage without adequate ventilation! The electrics in the 100 series are fairly robust, sometimes the problems you're seeing can be caused by residual moisture, not corrosion. It's a worth a shot to see if your electrics are still serviceable after being dried out.
Well the thing is that everything pretty much works at the moment. It hasn't leaked in a quite a while. The shop just said it's corroded and needs to be replaced.
Haha, don't do that. It sounds like you caught your problem early enough that your symptoms were only the result of residual moisture, and no serious corrosion has happened yet. The thing to do is: make sure your cruiser doesn't get rained on until the windshield is fixed, and get it fixed exactly like the factory service manual says to fix it. I'll attach a PDF of the relevant section of the FSM. The mistake that is frequently made is that the bodywork isn't thoroughly cleaned up and prepped after old windshield removal, and that the correct nylon rivets are not used to install the new windshield. Carefully read @2001LC 's thread here.
After you get the windshield issue fixed, I would recommend buying a roll of 3M 5557 Water Contact Indicator Tape. This is the same stuff used inside smartphones/laptops to detect water damage. It's white at first, and it turns bright red when it comes in contact with water. After you fix your windshield, remove your A pillar trim and put this tape around the inner part of the windshield seal. Also put some on your junction box and ECU. Then, you can periodically inspect the color of the tape to determine if you're still getting water ingress.
One other thing to think about is your sunroof drains. They run from the holes in the sunroof channel, down your A pillars, to underneath the car. It's clear, quarter inch tubing, you can see it if you remove your A pillar trim. When these get clogged, the water tends to end up in the wrong places. You can test your sunroof drain by opening your sunroof and carefully pouring water into the holes in the front part of the channel. You should see it drain out underneath the vehicle fairly quickly.
Wow, they really butchered it. Here's what I would do in your situation. Order ALL the parts you'll need to do the windshield job, including prep chemicals, rivets, trim, moulding, etc. Then have safelite come out and remove your old windshield. Then you can take a few days to clean/prep it yourself, wire wheel away all the rust, POR15, etc. Then, get them to come back and just place the windshield and leave. Then, you can do the rivets and trim yourself.
Alternatively, if you don't have the time for all of this, you could go to the Lexus/Toyota dealership, ask them to totally replace the windshield and all the associated trim, and hand them a bag of those nylon pop rivets and beg them not to take any shortcuts.
When you say the pillar is rusty, it's just surface rust right? Or is it beyond the point of no return?![]()
