Jim_Chow said:
<snip> Make sure they bleed the height actuator (cylinder-shaped thing under the left front rail) as well as the 4 globes. <snip>
Are you referring to the Height Control Accumulator?
That's the name given by the FSM to the only cylinder shaped AHC hydraulic thing on the left rail.
(Not to nitpick, but sometimes the Service Manager and others in Stealer Service Dept. will treat you as just another ignorant customer - e.g. lie to you etc. - if you use incorrect terminology.)
Yes, it should be bled too. Mine only discharged a very small amount of fluid when bled - but the first discharge was definitely full of bubbles etc., and that was on bleed date #2, meaning that the first time I bled only the corner Damping Force Control Actuators (globe thingies), the Height Control Accumulator did not get adequately bled.
The ride is definitely improved, after bleeding/flushing (twice...). Don't delay doing this bleed/flush more than the recommended 60k miles interval - I did, but I won't next time. The ride improvement takes a week or more to fully manifest, after bleeding/flushing. Interesting.
The ride quality degradation that gradually occurs over time with past-due deteriorated fluid is strange - the tiniest sharp bumps and road roughness are telegraphed directly into the vehicle system, rather than being absorbed and decoupled by the suspension. This also worsens a 45-55 mph cabin "boom" that is inherent to this vehicle (due to resonant frequencies in the overall system including the enclosed cabin air mass, I reckon). Now, all is better again after replacing the fluid & bleeding. Very nice to drive again.
On the "shocks" at the wheels: I expect that they are not "shocks" at all, not in the usual sense. More like combination hydraulic actuator cylinders / hydraulic pump pistons, without much built-in damping.
