Shifter knob removal (1 Viewer)
RFB
97 FZJ80 LIFTED SC DUAL BATTERIES,37s
Nahant Ma.
Website
www.youtube.com
how do I remove shifter knob without destroying OD switch can’t find it in FSM and it dosent want to come out
Think I just pulled a small screw out of the lower front(closest to the dashboard) and lifted it off ?
I was just in that area last night. If you remove the base plastic (the front part of the center console), there are several terminal blocks. Without looking at the FSM, my guess is that you unplug the terminal block and pull it out with the shifter.
  • Like
Reactions: RFB
I got it. Had to remove console and in plug blue connector and pull wire up and out. But now I have a new OEM leather shift knob good for another 250k
for anyone that may want to know, unscrew two very small philipps head screws from front of shifter lift up on knob, selector button(thumb) will fly across drivers floor then remove console(plastic cover) and remove at the base of the shifter towards back seat theres a blue connector block, disconnect and pull two white wires back out of terminal block this will allow you to remove OD selector up through shifter handle, install new handle and do everything in reverse. a NEW OEM leather shifter knob is awesome but pricey. I wanted it as the rest of the interior is slowly turning black and leather.
Shifter looks awesome, I'd love to just have mine recovered.
Im replacing everything its all done its time, pretty much everything on/under and in is new even tho it does not like it.
