It seems to me that SHORTER shackles would be the fix, rather than longer, if your springs seem short and you're at 90 degrees like that (before you invest in new springs or move the spring hangers). Yes, you end up with less shackle lift.
Although Guppie makes an inference about even longer shackles (damn though, mine seem pretty long at 4 3/4" c2c when I look around)... the bigger question is (1) how would you fix this in my case without anything radical - a different style of shackle - and (2) how would it get this way on mine that is SUA as compared to another that is SUA and not running nearly 90 degree shackles?
THEORY: Also, I wonder if a static photo of a sitting still vehicles shackle angle really relates well to actual real world usage? That is, as it sits, it is an issue. But, as it moves: gravity & momentum take hold, the body moves and springs load and flex and weight is added with people and what not so when you actually drive and say come across a bump or hole or rut, since the rig is in movement (+ previously mentioned variables), you might be hitting that object at a time where the state of the vehicle relative to those shackles is no longer at 90 degrees in the real world so no harm no foul???
I think that theory is somewhat tenuous, but kind of makes sense in a way to me. BUT, I still see no harm in trying to make a change so mine are not 90 degrees, but not sure how without a radical change.
BTW, I was looking at SOR and saw this photo..
not much better angle than mine in their sales literature.... gives one the impression that if theirs is okay mine is okay..
(1) You have to relocate the spring hanger or shackle hanger or get a longer spring.
(2) Your aftermarket lift springs are too short?
The major effect will be to limit droop. I can't see how it would limit compression or up travel. The effect on ride quality is not a big deal in my experience, so I would not do (1) above if this is your major concern.
Mark said *sometimes* increase the angle problem
big issue with shorter shackles is they don't let the spring flatten out as much when you hit a bump. I think generally, you'll get a better angle, but at a price.
I *just* put the Downey cantilever shackles on the rear of my 40 yesterday.
HUGE improvement in ride quality!
My horrible Pinnacle's started riding a bit better after i plucked the bottom 2 leaves out. But not until they settled after wheeling. . . This gave me a better shackle angle but dropped my rear end 2" - 3".
I just put the Downeys on which gave me the 2" - 3" back and gave me a longer shackle and a much shallower angle. (Mine are closer to 45deg as opposed to the Downey pic above)
Rides like a new truck!
so what is the downfall of an improperly angeled shackle? For example, mine are closer to 90 degrees (to the frame) - I assume it just adds to a harsh ride? and, how would you change just the angle? by changing the shackle out itself?
front
rear
Mine look like that, doesn't seem to affect the flex, but I always wondered why they won't angle out.
