I have a serious issue with my 80 that I need help with, especially since it’s my daily driver!
I was down to see Landtank to have him replace my Panhard bushings as I’ve been having a violent wobble that he traced down to the Panhard, he started to get into the job and we found that the inside nut on the axle housing clevis had broken free, it now just spins and is probably part of the problem with the bushing.
We tried to get into the back of the clevis so that we could remove the nut and bolt but that didn’t work, it also seems like I may have to do something about the possible elongation of the hole for the bolt. So at the moment we can’t get the bolt out, and we can’t get in there to cut it out, so the bushings can’t be replaced.
It looks like I may only have two options, having someone cut off the entire clevis and fabricate a new one, or fix the old one, and then weld it back on. Or buy a new axle housing, stripped, and have everything replaced!
Has anyone else had this problem! I can’t imagine I’m the only one. Any and all help would be vastly appreciated!
