Sensor Lift Question
texas
First off, I am new to the LX 570 world. So forgive me for my ignorance.
I attempted to do the sensor lift on my own and I missed a step, I believe. I kept the vehicle in normal mode adjusted the sensors to their highest setting and then put the vehicle in high mode.
Looking back I should’ve put in high mode first and then adjusted the sensors. It seems like an easy fix but before I mess with anything else, I just want to confirm with you all. Can I simply adjust the sensors back to normal while in normal mode and then follow the correct steps?
I.E. put in high mode, turn the vehicle off, adjust sensors to the highest setting, turn vehicle on and put back in normal. Would this be the fix or am I missing anything?
Thanks in advance.
There's no right or wrong way here. The mechanical adjustment is just a point of reference for the AHC system. It doesn't know whether the position shifted from an adjustment or suspension movement.
Note the direction you slide the adjustment is opposite front versus rear.
