- Year
- 1988
- Vehicle Model
- 60 Series
- Location
- Seattle, Washington United States
- Mileage
- 253500
- Color
- rgb(59, 155, 233)
- Outside Link
- https://post.craigslist.org/manage/7758281626
Selling as I'm moving to Australia in July 2024. I'm listing this early to start collating details and plan for a timed sale as this is my daily driver. If any Aussies are moving to the US in the same time period and looking for a swap, let me know!
More photos up on Craigslist - link above.
This has been in the Seattle area for it's lifetime. I purchased it in 2018.
Color: Light Blue on Dark Grey (25H)
My upgrades:
Maintenance:
Yearly checkups and all non-electrical work done at TorFab
Imperfections:
Sale inspection at TorFab on 5/21/24 - Results attached below.
Price: $25000 OBO before its time for me to fly out
My upgrades:
- ARB suspension with 2in lift
- BFGoodrich All-Terrain T/A KO2 LT31/10.50R-15 (14k miles on them)
- Hitch Receiver sand blasted and powder-coated (scrapes on the bottom)
- Desmogged. I kept the parts if you want to re-smog (actually I have a 2nd set as well from my prior FJ62).
- Dual battery with switched relay. You can jump directly off the second battery with the touch of a button which saved my butt a few times.
- Both battery trays are stainless steel trays.
- 12v bus in engine compartment connected to the house battery.
- ARB refrigerator running off house battery. Wired outlet to trunk behind driver side 2nd row.
- Upgraded alternator and ground wiring (ih8mud purchase)
- Heated LED headlamps with working high beams and high beam indicator (ih8mud build)
- Rebuilt AC with new compressor running of R134a -- blows cold air! (documented here)
- Touchscreen radio with backup camera.
- Sound deadening on floors, doors and quarter panels. Cascade Audio VMAX-HD and VB-2 vapor barrier.
- Almost all engine seals replaced over the last 4 years -- I've only driven an FJ62 for the last 20 years. No leaks is something new to me.
- Gamiviti Rack
Maintenance:
- 2018 New water pump and replaced radiator hoses
- 2019 Front and rear breaks - Front brake calipers replaced with 4runner calipers, ARB suspension
- 2020 New Radiator and heat pump
- 2021 Rain gutter reseal, side cover gasket, transmission service, heater core flush
- 2022 Transfer case rebuild & rear main oil seal
- 2024 New break lines, welded new cat (was clamped), engine tune up, new receiver-drier (leak at connection), driver seat vinyl repair
Imperfections:
- Driver seat side rip -- NOW FIXED!
- Quarter size rust bit on driver side door (see photos). Early rust on c-channels
- Holes drilled at the front of the hood, I assume for a bug shield with prior owner (you can make them out in the first photo, more to come)
- Rear windshield wiper fluid not working. There is a break/disconnect in the hose somewhere.
- Dent in driver rear bumper (see photos).
