Anyone have an idea on how long they typically last? It's a minor frustation for me for the belt not to retract much, so I was wondering if it'd be worth while springing for new belts.
my two rear belts did that. It turned out that they were folded over a little bit then retracted and I couldnt even pull them out all the way. I unbolted them and drilled a small hole in the plastic on the seethrough side and stuck a pick in there to lift the lever that holds it in. I then pulled out the belt, straightened it out then retracted it and it works perfect now. Anyway, im not even sure if that is what the problem is but if so, I hope it helps.
Goodluck,
Paul
