- Thread starter
- #61
Thanks Tom.
Yes they certainly are suspect. I'm getting some new ones fabbed up next week.
QUESTION: Below I've attached a photo of the right side with the oil cooler cover plate removed. Circled in red there is a hole. This hole does not correspond to one on the cover. In other words, when the cover is on, it acts as a cap instead of as the other half of the passage.
When I pulled the cover, this hole was packed full of Black RTV Silicone. i grabbed the trusty pick set to try and extricate said silicone plug, and unfortunately popped it back into the block.
So, the questions are; can anyone tell me what this passage is? Is is it part of some critical lubrication circuit that will cause damage if blocked with a stupid little silicone plug, or is it just some vestigial hole from the manufacture of the block? Can anyone recommend a method of extraction? Tomorrow I am going to experiment with some straws and a shop-vac, but I see frustration in my future...
Next, Just because I'm curious, what belongs in the two holes shown in the next picture? These are down low, on the right hand side toward the rear of the engine block.
Last; I was expecting to find an actual oil cooler behind the cover plate instead of just a chamber. Is the cooler just a 3B thing? If the cover with no cooler is characteristic of the B/2B, will a 3B cover fit, and can one introduce an oil cooler to the equation?
's car right now.)
