Ok guys and gals we all know how to search when something breaks but I wanted to share mine because knowing in advance could save you some trouble. Well a few weeks ago I slid my PS seat full forward to get some wood in the 80 and sure enough, the seat was stuck and would not move back. One of the seat screws would turn a little bit but bind almost instantly. So after a quick search I found that the sweet little nylon screw in the picture had popped out. The repair is simple with the exception of me having to remove the seat. One thing to remember is that you don't want to over tighten as it will keep the seat from moving as well.
Ok so the thing that makes this post different is that anyone with an 80 (not sure if this part is there on the hundy's) is that most of the times when these pop out you don't even realize what they are. The thing I noticed was how many people threw them away or scooped them up with a vacuum at a car wash or your shop vac. They are located at the front of the seat bracket by the center console. I found my nylon screw at the rear of the seat by the rear door. No where near where you would have thought it would have ended up. Had I not know what to look for it could have ended up in the trash and I only know of one place to order them from.
So if you own an 80 you might want to make sure yours have not backed out and now if you see one of these you will save yourself some trouble. Hope this helps someone down the line.
R
